Hallo,
I tried the latest ProgDVB Version for Win7 64bit with TT-S2 3200 PCI as the Server, and Win7 32bit as Client. I scan on Astra 1L,M,H... and get many Channels. Most Arabic, Turkish and the HD Channels.
The Streaming to the Client works very well.
But there is no ARD, ZDF, Pro7/Sat1 or RTL Bouquet with the "normal" German Channels.
It´s look like that the Channels on Astra 1H are lost.
But in MCE or other DVB Viewer are all Channels present.
When I scan Transponders I see that on the ARD Frequenzy 11836 H the Signal is 65% but the Quality is 0%. The same is on the RTL and Pro7 Programs.
I installed ProgDVB any Times and with any Versions (after uninstall) and some Satellite scans later there is the same result.
Can Enyone help me?
Thank´s and kind regards, Rolf
Update: Under Freq 11836 H (where normally is ARD) the Signal Quality is 0% and no Program,
but under Freq 11836 V the Signal Quality is 100% and there I scan the Italian RAI Programs.
Re: Problem with Astra 1H
#2Something must be completely wrong.
On Astra 19.2°E, you don't find Italian stations around 11836V, but a lot of French.
Many RAI stations are on Hotbird 13°E, around the frequency given more or less....
Did you move your dish?
Or do you have more than one LNB?
To allow finding out more, please provide us with exact details on a couple of stations found, including basic IDs from channel props.
#3Hi Juergen,
we have 2 LNB. Nr.1 for HotBird Nr.2 for Astra.
In the Settings I have also installed the two LNB and give them Nr. 1 and 2. Power is On.
Could it be that the Diseq dont switch?
Sorry, but iám an Amateur
Greatings Rolf
Greatings Rolf
#4OK, I can help me with a trick: First I started tt-viewer and switch to SAT1, then I found the lost channels and all is goof
