HEllo
I have on my PC a Wintv nova-T and a Wintv-nova-S-plus
I would like to use both card with prog DVB at the time BUT, I can enable both at the same time.
Is it really possible as reading forums, some are saying yes, other say that I need to have 2 installs of progdvb
Thanks for your help
Hi , i think the Problem is ...both cards using the same (and only) physical bda device ...
The other bda devices you see in progdvb device list are only registry entries that point to the same physical bda device (\progdvb\modules)...
resolve this problem
try used progdvb ex. with Wintv nova-T
and other not progdvb with Wintv-nova-S-plus
No
I have
1 PC ...
for now, 2 DVB cards : 1 DVB-S, 1DVB-T ...
I went forward on my problem, some people propsed to me to use only one card , the sat one as the channels from are provided in clear on some sat .
1 prob, I can only catch the encrypted one
any idea ?
I have
1 PC ...
any idea ?
mm? sorry, I 'm really new with progdvb ...
Important information : I have a wintv nova -S-plus and wintv nova-T ....
nova-S pnly works with progdvb 4.62 ( the 4.80 generate an error and can't start device )
sorry sorry, I'm not very helpfuul on this ...( and my english is bad )
I have
a haupauge wintv nova T
a haupauge wintv nova-S plus
Before , some post said that there was a conflict, so for now, I have on the nova-s installed in the PC ...
If I try to start the device called {BDA} DD DVB-S ..if works ( not in 4.80 )
is it more clear ?
Thanks !
I have
is it more clear ?
Thanks !
