Timeshift buffer is overflowed!
jaffo
jaffo
Sat May 17, 2008 11:12 pm
Lincoln, UK
#1 by jaffo
After 5 or 10 minutes I get a message "Timeshift buffer is overflowed!"
I have the buffer size set to 128mb.
  • Sat Jan 29, 2011 2:43 am
Re: Timeshift buffer is overflowed!
What demultiplexor you use?
  • Sat Jan 29, 2011 10:09 am
jaffo
jaffo
Lincoln, UK
#3 by jaffo
Microsoft
  • Sat Jan 29, 2011 2:53 pm
#4 by Prog
That looks like bug in ProgDVB. Is it depended from channel? From video codec?
Try other demux also.
  • Sat Jan 29, 2011 2:57 pm
Вы мне логи крашей присылали?
  • It is currently Sat Jun 27, 2026 11:57 am
