Atm it seames i have rilsolved but after 21 days i eill be sure i have done realy al ok 100% i have done:
1)I unistalled Elecard AVC PlugIn for ProgDVB 1.2.90105.exe
2)I unistalled pRogdvb 6.51.02
3)I installed Elecard AVC PlugIn for ProgDVB 1.2.90105.exe (and in the tegistrator of the program i can see the versions of the plugin installed
4)I have installed again Progdvb 6.51.02 and olso in registrator of Progdvb i can reade the same version of the plugin elecard installed so mybe the problema was a not correct installed pluging during the setup not sure but i say i just think...let we wait
Thank's
Helen
ok so...Now all is ok but with this nrw plugins (i think is that the problema kust because is the only thing i have changed) when i revord something the file mpe is traly big (20 minutes over 1 gb).Yes after i use another software that compres/convert in xvid the file and reduce it about 1/5 but,as i thik the problem is on this news coides that are bettar i supose if the big size of a file is equal to the quality of the video.Can u suggest me a setting taht i can use so that to dont lose to mutch quality video and reduce mpeg file dimention?
Last question (OT)...
To upgrade progdvb version i nade to unistall the older one or i just nesade to lauch the new one (version) and everything will be done automately?
Allways tahnk's for the good support u giving me !
Take care
Helen
