shift key does not work
A.S
A.S
Fri Apr 01, 2011 12:45 pm
#1 by A.S
Hello,
I have a problem that when I run Progdvb the shift key does not work.if I press alt+shift it do nothing.
My OS win7 x64
thanks
  • Fri Apr 01, 2011 12:59 pm
Re: shift key does not work
Check Settings->Options->Interface->HID options->Foreground only
ps: It is bug of HID module.
  • Fri Apr 01, 2011 4:01 pm
A.S
A.S
#3 by A.S
great works,
thanks
  • Fri Apr 01, 2011 8:06 pm
  • It is currently Tue Aug 25, 2026 2:47 am
