Hi there
Please can you be kind enough and tell me why the progdvb can't find out bda for tevii S660...???
Best regards
Carlos
Re: Problem with TeVii S660
#3Thanks for your quick replay, but as a beginner i can't find where i'll can do this ( Please put screen of TV Sources of ProgDVB) please can you help me more ?
Best regards
camane007
Best regards
camane007
#4[size=50] Железо: Acer KG271C, IP Q G2020@2.9, HD7770, 8 RAM, AMD audio, Yamaha RX-V465, LG 42LA790V, Prof 7300,7301, Tevii s470, TBS 6922se. Софт: W7x64, ProgDVBx32. Настройки: prog demux, audio-AC3Filter, WASAPI, video-Custom EVR, ArcSoft 2,28,497 [/size]
