Hi,
I've got Prgdvb. professional installed on a Vista computer with prog Media Server (small). I want to connect another computer via the server and want to be able to change channel on the server. I've management to get it working on my laptop with Windows 7. But with my desktop computer with XP, de client craches when I try to change the channel. I've tried installing a view times but no succes. Any idea what kan be the problem?
Re: Client crashes when changing channel
#2What mode of server? Do you receive channels on client over scanning?
#3I have! Change client to W7.grobbeton wrote:I've management to get it working on my laptop with Windows 7. But with my desktop computer with XP, de client craches when I try to change the channel. I've tried installing a view times but no succes. Any idea what kan be the problem?
#4Current channel mode. There is contact with the server. I'm able to load the channellist from my server. ProgDVB stops when I try to select a channel
#5Tried to get it working on a Vista PC. Same problem. Can connect and get channel list. When selecting a channel, ProgDVB engine crashes..
#7On the client the standard and on the server Pro. latest version. I decided to install Vista on the client a few ours ago. Isn't a 100% stable but it works now. Sometimes prog hangs, but now i'm going to try to work with the settings to optimize it..thanks for the quick respons.
