Client problem
Hi,
Last week I posted a message that my client (Pro version) crashed on XP. I solved this by using Vista. This resulted (after again a few crashes) in a working system. But now I've got it working, iIts not stable at all. Every time when I select a channel, it streams fine for 3-4 minutes. After that sound and image start to stutter. I have to reselect the channel again to get it working again. I've tried several settings but I do not know how to solve this problem. I've installed the client server mode.
can someone tell me how to get it stable?
Re: Client problem
I've installed new versions of ProgDVB Pro en Small MediaServer. These seems to be more stable versions but problem still excists. I got it working in client changing mode. After a few minutes the streamindicator (bottom left) turns grey and no stream seems to get through. I have to reselect. Also a problem now when changing from HD to SD channels. Stream HD oke, no stream comes trough with SD. Could someone help me get in working...
Is it a codec problem? Or could it be a port problem? Server is in client server mode because I want to be able to change the channel on de client side. Got the multicast protocol setup. Could this be the problem?
