currently based out I have 2 tuner, a DVB-C KNC and other SkyStar HD2.
I have them configured properly, I detected and all channels ok. The problem comes when I play to change the channel disappears conplete program gives no error but disappears. I have to open it 2 times to return to work and tells me the following. return to the state last worked properly.
that may be the problem?
thanks
Re: problem with progdvb
#3Re: problem with progdvb
#4Try install not in program files with config files in same directory. May be ProgDVB not access to ProgDVB.ini
#5I tried to re-install everything from 0 but nothing ProgDVB unexpectedly quits. does not give me any error messages or anything. I recently changed procesaro intel amd x4 to x6 but I guess that has nothing to do.
however other programs like dvbviwer me working properly.
