ProgDVB 6.63 problem
Ilir
Ilir
Sun May 08, 2011 11:04 am
#1 by Ilir
After 6.63 installation (6.61 before), I can see some squares (logo?) on the screen (top-right). What is it? Can I remove it? I tried to install old version, but squares won't go away.
  • Sun May 08, 2011 11:13 am
Re: ProgDVB 6.63 problem
It is trial function of Elecard video codec. You can select any other codec installed on your PC.
  • Mon May 09, 2011 6:09 am
Ilir
Ilir
#3 by Ilir
OK, now I understand. First time, I disabled trial function during installation, this time I forgot. Thanks.
  • Mon May 09, 2011 7:58 am
  • It is currently Tue Aug 25, 2026 2:46 am
