Channel list conversions
    • ProgServer
    • ProgMusic
    • ProgFinder
    • Elecard ViCont
  • Privacy Policy
1 post
goodwill_dish
goodwill_dish
Fri Nov 17, 2006 2:03 am
#1 by goodwill_dish
Hello,
I use an earlier version of ProgDVB with a SS2 DVB card, basically because I am afraid to lose my settings if I were to upgrade :oops:
I am interested in being able to convert Coolsat .NDF channel lists for use in ProgDVB as the SS2 does not have blindscan capabilities and FTA channels seem to be under constant transition.
Any relief would be appreciated.
  • Fri Nov 17, 2006 2:20 am
1 post
Re: Bug - Missing First Chara…
You can try prerelease of ProgDVB https://www.progdvb.com/download_progdvb_prerelease.html and enable "original name" in
Prog, Sun Nov 01, 2026 7:57 pm
Do you mean "US| DISCOVERY HD appears as S| DISCOVERY HD"=>DISCOVERY HD? ProgTV/ProgTV must create folder for "DISCOVERY
Prog, Sun Nov 01, 2026 6:04 am
Bug - Missing First Character…
Hello, I have encountered a reproducible bug in recent versions of ProgDVB Standard. Problem: The first character of ev
vivre, Sun Nov 01, 2026 1:38 am
  • It is currently Tue Nov 03, 2026 7:57 pm
