Win98SE, PII 450 MHz @ i440BX, Nexus-S 2.2 @ driver 2.19, plain HW mode.
"Receive mpeg2 from Skystar1" set inactive (for better mpg recordings compatibility).
L 100%, Q perfect, of course.
Since after 4.75, the slider does not work at file playback, .mpg and .pva
Also a lot of .mpg recordings don't play at all, though playing OK on 4.75 or older versions. Valid for .mpg recordings of any age, latest tested to fail was made with 4.80.5.
Still the keyboard does not control the channel selection soon after start of ProgDVB, focus is not set. Mouse action required once...
Starting ProgDVB by ProgDVBLauncher fixes this, but ProgDVB should be able to set the focus properly alone...
Still the original EPG loses all function after some time on or after leaving Astra 19.2E ZDF transponder (mainly). Closing of ProgDVB results in two crash messages then, though those can be ignored, to close regularily.
Last perfect working EPG.Module was 1.03 (from 28 April 2003 / came with 4.14.1fullinstall). But that's not compatible with newer versions, since 4.2x.
Mentioned all this on the old forums more than once, last one even years ago...
Never give up
