Hi everyone,
I'm using progdvb 6.63.5 under win XP SP3 but already had the problem with previous versions.
I have problems with the end time of some records.
Typically, the last record I have done was scheduled to end at 0h30 and actually ended at 22h30.
I was wondering if it could not be a problem with summer time, or time zone (I live in France)...
Thanks in advance.
ArnaudN
Re: Record duration problem
#3I have not exactly checked for the previous too short records but I think yes.
By the way, I can say that if the record end time is after 1h00 or 2h00 (to be confirmed) (I can make tests next night) the record is OK.
#4In case it would help, the scheduler options are :
- Use microsoft scheduler to start progdvb
- sleep timer disabled.
But my records are done while progdvb is running.
Records options are: no option checked.
#5I did several recording tests to try to have a better description of the problem:
- With 6.63.5 : recording ending after 2.00
- With 6.63.5 : recording ending between 1.00 and 2.00
- With 6.63.6 : recording ending between 0.00 and 1.00
All these recordings ended at the right time and had the right length.
Maybe the previous wrong recordings were due to bad quality signal...
#7Hi everyone,
I think I have found the cause for the short records.
I have seen that when the progvdvb engine restarts (message in the status line), the record stops!
Don't you think that it should not ?
I understand that the record should be stopped while the engine restarts, but maybe it could be possible to restart the record in a new file, with an index, or something...
Anything would be better than nothing.
#81. Please start with /EngineLog send send me two files ProgDVBEngine*.log.
2. You can disable stability mode for fix that.
#9OK, here are the logfiles.
The engine has restarted at 20h35'29"
What is the impact of disabling the stability mode on the records ? (glitch in the file ? sound/image desynchronisation ? ... )
- ProgDVB.zip
- Logfiles
- (141.13 KiB) Downloaded 401 times
#10No restarting engine...
ps: My log too bad for this situation. I try more tests on my PC.
#13I have already done 3 records with 6.63.07 and turned off stability mode.
Two out of them ended normally and the third one ended after about 9 minutes.
#15I have installed 6.63.8 in stability mode.
I have scheduled a 2h30 record which stopped after about 11 minutes.
I'm using a USB pinnacle PCTV 320e, in case it helps...
