ProgDVB Does not Save CHannels
waelabdo
waelabdo
Thu Jul 07, 2011 2:48 am
#1 by waelabdo
I used channel list and then scan transponder and then i got the channels needed and then pressed OK.
but the new channels aren't saved at the channel list.
any answer for this strange problem ?
thanks
  • Thu Jul 07, 2011 2:52 am
Re: ProgDVB Does not Save CHannels
Do you select position in scan transponder dialog?
  • Thu Jul 07, 2011 5:07 pm
  • It is currently Tue Aug 25, 2026 2:03 am
