Re: Problem in your program ProgDVB
unstill any driver u have on your computer
download this file
http://www.dvbsupport.net/download/inde ... iew&id=183
install the driver form this file u dont need to install any extra things like player
then after all that done you will be able to watch the normal channal on progdvb not the hd
to fix this put the sky star hd2 cd driver and update the 2 driver they belong to this card if you dont know them just install the cd like normal then when u run the prog dvb just choose bda combatble it wil work fine
That link is broken.
If a link seems to long, to be posted here as such, post it inside of quote or code tags.
People over here should be able, to use copy and paste then...
