diseqc 4*1 problem in ProgDVB6.65.2Pro and ProgDVB6.70.3Pro
star
star
Sat Jul 23, 2011 11:05 pm
#1 by star
when search in when search in sat port 2 or 3 or 4 get channel from sat port 1
this very bad version
  • Sat Aug 13, 2011 10:59 pm
Re: diseqc 4*1 problem in ProgDVB6.65.2Pro and ProgDVB6.70.3
What device you have? It is most depended from hardware and driver.
  • Sun Aug 14, 2011 4:42 am
star
star
#3 by star
Prog wrote:What device you have? It is most depended from hardware and driver.
tevii s464 final driver
  • Tue Aug 16, 2011 2:18 am
#4 by Prog
tevii is good device. Do you have same problem in other software?
ps: Check Settings->Device options. Must selected tevii and try change repeats and delay values.
  • Tue Aug 16, 2011 4:41 am
star
star
#5 by star
Prog wrote:tevii is good device. Do you have same problem in other software?
the problem in new 2 version !
no in ProgDVB6.65Pro
iam try all no change !
the card work good with all other software !
  • Wed Aug 17, 2011 4:09 am
  • It is currently Tue Aug 25, 2026 2:03 am
