I have the following problem with ProgDvb since version 6.63.10
What happens is when I start the ProgDvb it crashes allways. with the following errors:
version 6.70.3:
Description:
A problem caused this program to stop interacting with Windows.
Problem signature:
Problem Event Name: AppHangB1
Application Name: ProgDvbNet.exe
Application Version: 6.70.3.0
Application Timestamp: 4e454103
Hang Signature: a76c
Hang Type: 773
OS Version: 6.1.7601.2.1.0.256.1
Locale ID: 1026
Additional Hang Signature 1: a76c6a7781ae6c05b6d52e7ff7198cdc
Additional Hang Signature 2: 0104
Additional Hang Signature 3: 01044693980d4283e883c295a185a284
Additional Hang Signature 4: a76c
Additional Hang Signature 5: a76c6a7781ae6c05b6d52e7ff7198cdc
Additional Hang Signature 6: 0104
Additional Hang Signature 7: 01044693980d4283e883c295a185a284
and version 6.63.10 where the problem starts.
Description:
Problem signature:
Application Version: 6.63.10.0
Application Timestamp: 4e0dad53
Hang Signature: 7805
Hang Type: 773
Locale ID: 1026
Additional Hang Signature 1: 7805b234fe81c885662b19f15c02fd97
Additional Hang Signature 2: 6765
Additional Hang Signature 3: 676592b6ce76040e4e95cfaee31424c1
Additional Hang Signature 4: 7805
Additional Hang Signature 5: 7805b234fe81c885662b19f15c02fd97
Additional Hang Signature 6: 6765
Additional Hang Signature 7: 676592b6ce76040e4e95cfaee31424c1
Then I close the ProgDvb and on the next start I choose Resset All.
Then go to TV Sources, (all sources are disabled because of the reset), Choose my TechnoTrend Device.
Then Prog is working perfect. Watching the scrambled channels etc. Until I close the application.
On the next start the same error, the same procedure with reset all settings.
I tryed the 6.63, 6.63.7, 6.63.8, 6.63.9 all work OK. When I close the ProgDvb on the next start everithing is OK working etc.
There is onother thing that is a bug I suppose.
The ProgDvb on restart opens the last channel you were watching.
So on most versions at least for the last year there is a problem I don't understand.
For example on all the 6.63 versions if I close ProgDvb on scrambled channel. On next start ProgDvb opens the channel but it cannot descramble it. It stays black screen.
If I go to a free channel which works right away and then go back to the scrambled channel it starts descrambling the channel.
Older versions had similar bug but instead of going to free channel, you could have just reselect the scrambled channel and it have descrabled it.
on the 6.63 this does not work, you should mandatory go through free channel in order to see the scrambled channels on start.
Then after this procedure on start you can switch the channels fine.
Cool Program.
