Problem with Scheduler
dj.koala
dj.koala
Wed Mar 09, 2011 11:05 am
#1 by dj.koala
The latest version of the softvare will not start scheduled recordings if the program is turned off. What should I do?
  • Tue Aug 30, 2011 8:26 pm
Re: Problem with Scheduler
What scheduler mode? What last good version for you?
  • Wed Aug 31, 2011 6:54 am
dj.koala
dj.koala
#3 by dj.koala
Prog wrote:What scheduler mode? What last good version for you?
What is scheduler mode? Last good ProgDVB v6.70.5
  • Wed Aug 31, 2011 2:48 pm
#4 by Prog
Settings->Options->Scheduler
  • Thu Sep 01, 2011 6:46 pm
dj.koala
dj.koala
#5 by dj.koala
Prog wrote:Settings->Options->Scheduler
  • Thu Sep 01, 2011 8:02 pm
#6 by Prog
Check ProgDVB items in MS scheduler after add task in ProgDVB.
  • Fri Sep 02, 2011 5:26 am
  • It is currently Tue Aug 25, 2026 2:03 am
