progdvb can't find channel with axtrom
acer20006
acer20006
Tue Aug 30, 2011 7:26 pm
#1 by acer20006
hii all .
i have axtromDVB201 it's work with it own software but when i setup progdvb and update the driver list , signal show-up but there is not channel found when i start the scan ,,,,,any help ?
thx
  • Tue Aug 30, 2011 8:29 pm
Re: progdvb can't find channel with axtrom
Same problem in Manual Scanner mode? BDA driver?
  • Wed Aug 31, 2011 6:51 am
acer20006
acer20006
#3 by acer20006
Prog wrote:Same problem in Manual Scanner mode? BDA driver?
yes BDA
  • Wed Aug 31, 2011 2:48 pm
#4 by Prog
You can try other mode in Settings->Device options. kworld for example. Also try disable "Use ITunerRequest"
  • Thu Sep 01, 2011 6:41 pm
  • It is currently Tue Aug 25, 2026 2:03 am
