am have satlietcard ( pixelview PlayTV 700 DVB-S )
and program progdvb 3.4 support with it and i want to setup progdvb 3.81 the last verision but i dont know which device i can select during setup i cant find my card in the device list supporeted with progdvb
am hope to help me in this problem
in your old progdvb version...its so difficult ???SiLencer wrote:then look in device list which device is used...
menu : settings->device list...
Old ProgDVB full install packages up to about 4.4x can be opened directly with many unpackers, without installing.
You can as well make a bogus install into a temporary folder, without selecting a device.
Learn to use Windows Explorer...
And Windows Editor / Notepad, to look into .ini files f.e.
And please, be precise with numbers.
ProgDVB 3.x would be VERY outdated.
Though, may still work for the cards it already supported years ago...
