ProgDVB x86 6.80.01 Reset button
Terijan
Terijan
Mon Dec 05, 2011 3:43 pm
#1 by Terijan
Help -> About me -> Reset button do not works. If i press it - it does nothing.
  • Mon Dec 05, 2011 3:47 pm
Re: ProgDVB x86 6.80.01 Reset button
This button for reset statistic.
  • Mon Dec 05, 2011 4:31 pm
Terijan
Terijan
#3 by Terijan
Yes. It do not does what it should do.
  • Mon Dec 05, 2011 6:03 pm
seba
seba
Sun May 25, 2008 5:31 am
#4 by seba
Indeed the the Reset button doesn't work.
  • Mon Dec 05, 2011 6:33 pm
Terijan
Terijan
#5 by Terijan
In 6.80.02 version this issue was fixed. Thanks!
This topic can be marked as closed / solved ...
  • Thu Dec 15, 2011 6:35 pm
  • It is currently Tue Aug 25, 2026 12:01 am
