Hi guys , i have both a skystar2 hd ci usb + Cablestar Combo Hd Ci usb
now the problem is they cant just live together .
If they r both connected i get a black screen on both devices.
If i disconect one of the 2 , the one connected works great as it should.
It's a 100 % prog dvb problem ( and its so bad sucking hardware support i must add)
because when i use dvb viewer pro they work great nothing to disconnect......
It also does not seem to support the ci of the cablestar nor the wintv-ci ( hauppage).
I dont think they gonna fix this problems anytime soon .
If you guys have any idea to make the 2 recievers work together i ll thank you but honestly i m hopeless.
It a Shame for a program which costs almost 3 times Dvb viewr pro.
So i m problably deleting Progdvb for good this time .
Im simply tired of it and its non existent hardware support.
Re: Progdvb skystar2 hd ci usb + Cablestar Combo Hd Ci usb
#2Quick solutions is Settings->Device options->Not start more device at once.
But your devices must working at once also...
#3Thank You , but i already tried that .
Didnt work the only way i have to make one reciever work its phisically disconnet 1 of the 2 recievers .
Its clearly a progdvb issue not being able to make both recievers work together.
And anyway technisat its being around for ages so its not admissible it doesnt support the ci .
Again i repeat progdvb its a piece of crap due to its lack of hardware support,
And its a shame cos it wouldnt have been one of the best software around otherwise.
#4btw, what manufacture of "Cablestar Combo Hd Ci usb"? First device is azurewave (in in device options must be selected Azurewave). But I am not have second one in my collection.
#5They r both technisat
and tried that
no go
btw again its not a hardware setting or a reciever issue
The issue is progdvb which cant make the 2 recieve work togheter .
If i desconnect either of them all works fine................
and tried that
no go
#6Yes, of course problem in ProgDVB. But I need some idea why. I have USB 2 HD CI device in my collection. Really this is azurewave and very good driver without any problems in ProgDVB. But I am not have cablestar combo and not can test they both.
1. try enable azurewave mode for both
2. Check Settings->Options->Debugs->Logs and send me all files from Logs directory if still problem.
#7Prog wrote:Yes, of course problem in ProgDVB. But I need some idea why. I have USB 2 HD CI device in my collection. Really this is azurewave and very good driver without any problems in ProgDVB. But I am not have cablestar combo and not can test they both.
Didi it , no go
For prog dvb the 2 recievers simply cant live together .
#8Some users have more 10 receivers at once. It is not problem. But some specific of driver...
#9Prog wrote:Some users have more 10 receivers at once. It is not problem. But some specific of driver...
Its not a driver issue , or else other programs would not work either.
Instead dvbview handles them both together with no problem whatsoever.
Actually i have gone even further dvbviewer even handles the 2 ci interfaces embended in the reciever plus a ci reader usb altogether.
They invented BDA architecture for a reason , the programs which follow the standard as they are supposed to have no problems hadling all the recievers they should at once .
#10Every manufacture have self BDA...
ps: CI and diseq is not part of BDA.
