DM 1105dvb-s pci card not working with progdvb engine 5
habib2005
habib2005
Thu Apr 22, 2010 2:05 am
#1 by habib2005
I had DM 1105 dvb-s card and is working perfect with the latest version of progdvb based on the the pre-last engine 4.66 (progdvb 6.61.01 ) .
the newer versions detect the card and signal correctly but can not scan for channels and the pre designed channels also not working .
I wish you can help me with this problem .
  • Fri Feb 03, 2012 10:39 pm
Re: DM 1105dvb-s pci card not working with progdvb engine 5
Do you have BDA driver?
  • Sat Feb 04, 2012 12:42 pm
habib2005
habib2005
#3 by habib2005
This is no stable BDA driver for this chipset. however the WDM driver is working as i said.
  • Sat Feb 04, 2012 1:36 pm
#4 by Prog
WDM have some specific API and modulec.
  • Sun Feb 05, 2012 5:56 am
habib2005
habib2005
#5 by habib2005
The question now is there any possibility to solve this problem of incompatibility between the WDM driver and the current modules to work with the engine 5 ?
I can attach the driver and the current modules working with the latest version of engine 4 .
I hope you can help with this problem.
  • Tue Feb 07, 2012 1:17 pm
#6 by Prog
I am not know author of old module...
  • Sat Feb 11, 2012 4:50 pm
  • It is currently Tue Aug 25, 2026 12:37 am
