ProgDVB - Free
Hi to all,
I would like to know if somebody has my same problems.
Seems that the problems concern the skin option.
On certain programs selection I have a deformation of image (more width), If I change Skin option and I close and re-opne the software the image become normally.
Thks
Re: ProgDVB - Free
Prog wrote:What version of ProgDVB? ProgDVB not change skin without restart.
Yes it's true, I can not change the skin with-out restart, but if I select the same skin as the previous, on option menu, the problem seems being solved.
Pls note that the issue it's tied only on certain channel, not happen always.
Attached version img.
Re: ProgDVB - Free
grobnik wrote: Here attached a screen shot.
thks
Its not problem of the skin-all proportions are right. For changing picture aspect ratio-right mouse cliсk on video->aspect ratio->auto
Re: ProgDVB - Free
thks
I disagree because if you set the aspect ratio of such channel, then you switch to another TV channel, and come back on the channel affected from the issue, the aspect ration should not change, in fact the aspect ration does not change.
So in my opinion, the issue has to be searched in some bugs, I remember that several software version before there was the same issue.
Thank you for your support
Re: ProgDVB - Free
grobnik wrote:
thks
In the program there is very good function(which are not in other programs)-memorization geometry of each channel apart.
Check in Geometry Optiots too.
And ones more-Its not problem of the skin-all proportions are right.
Re: ProgDVB - Free
The Geometry option, below indicated setting are not specific for such channel, but are setting in general option menu:
Border 0%
Video Ratio None
adjustment None
(the above option are in translated from Italian language, so could not be the same in english software version).
Re: ProgDVB - Free
Display ratio-real proportions of screen/Right click-auto/
All above-provider fault
