I'd like to ask everybody of you who have got approx. the same configuration like mine whether you have managed to get a diseq working.
No matter I do, no matter the setting progdvb is only showing image form one LNB (depends wich is first configured most of the times). So once I can watch programs form Astra 19.2 and not even one form Hotbird 13.0 and then after some config changes overt the TV source it becomes sometimes all the way around -I can watch hotbirs and no astra!
Changing programs form channels list does not do anything. Manual scanning is not working (no signal on one of the LNBs).
I have used all the possible setting for TV source form tone switch to diseq 1.1, changing the order of LNBs, etc - nothing worked. When I use DVBviewer from technisat pack switching channels runs with no problems.
I was just about to buy the Prgdvb PRO (now I'm testing trial) because I was pleased with version 4.85 (and then it worked for me with the same 22kHz diseq switch with no problems). Now I am really confused
Many thanks in advance for you replies
