Hey.
I have a GeniaTech DigiStar DVB-S PCI Card and use the latest ProgDVD.
My Problem: I'm from germany and I need the Astra 19 and 28 sattelite. But they are not in the List (or I'm too stupid...). And on Astra 1H, which is i the list, are no stations (my parents receive Eurosprt on 1H). I have about 55% signal but 1% quality.
BTW...My prog crashes very often. Everatime when i search stations, change card or a after few seconds in the tray. With the CD Version it doesn't happen
Can anyone help me?
THX; Horst.
Hi , transponderlists for scanning you can get here : viewtopic.php?t=27I need the Astra 19 and 28 sattelite.But they are not in the List (or I'm too stupid...).
Use the version from the CD...In newer versions of progdvb your card is not well supportet...
Yeah. They are in my list, but my satelite (astra 19) is not included. Do you mabe have another list??
then try with your progdvb cd version...if this don´t work too i only can help you with this : viewtopic.php?p=1747#1747
