OS: win7 x64
DVB-T/T2 card TBS6220
Country: UK
Demultiplexor: Prog
Audio Renderers: Prog
ProgDVB works normally with DVB-T channels
when i switch to view a DVB-T2 channel such as BBC HD i get the following:
"Pin for connection not found
Stream type: AAC - Audio
Please check up Settings-> Options-> Video and Audio, Probably one
of necessary codecs is not chosen or not installed on your computer.
Second try:Error in default graph building!"
so i think, no problem ill it switch to one of my AAC codecs!
when i try this however, not all of the AAC codecs i have installed show up on the list. only 4 do, and none of these 4 work.
here is a screenshot:
When i use TBSViewer, it shows 8 codecs. TBSViewer plays back DVB-T2 channels such as BBC HD. When i checked the codecs in the same way on TBS Viewer i saw the following:
So whats my problem you ask, why dont i just use TBSViewer to watch HD?
Answer: The prog demux is FAR superior and i prefer the ProgDVB interface.
Any solutions please? thanks for any help.
