Hi,
i just installed the 6.84.05 free version of progdvb on my WinXP SP3 laptop. I use the Terratec Cinergy TStick RC.
So i do this the 1st time and it finds tv stations and when i open them i get clear sound but the image stays black.
On every channel i get the same error:
"Error connection of Video Renderer! Stream Type: MPEG2 Please check up Settings->Options->Video and Audio. Probably one of the necessary codecs is not chosen or not installed on your computer.
Second try: Error in default graph building!"
So i installed ffdshow_rev4436_20120422_clsid.
Under Settings->Video->Codec->MPEG-2 I then selected ffdshow Video Decoder.
But the problem remains.
Please help me
Re: Error connection of Video Renderer MPEG2
#2Need enable ffdshow filter for use with MPEG2 stream.cassinni wrote:Hi,
Please help me
viewtopic.php?p=48092#p48092
#3i did enable mpeg2 in ffdshow->codecs. i chose libavcodec and hit ok but every time i start ffdshow its back to deactivated.
I dont understand this, i just enabled it and its disabled every time. Is there a better codec or a more simple approach?
thanks
thanks
#4Run as Administrator?cassinni wrote:i did enable mpeg2 in ffdshow->codecs. i chose libavcodec and hit ok but every time i start ffdshow its back to deactivated.
thanks
This ffdshow not good display stream video. Try download and install other codecs.
My list viewtopic.php?p=48038#p48038
Try download...by google example.
My choose CyberLink PowerDVD 12.
#5thanks for your reply.
I installed the new PowerDVD12. I could not select the PowerDVD codec in progdvb.
So i found a guide on google.
I did this:
1. Download latest filtergraphs
2. Extract it to progdvb into a dir that i created called \progdvb\filtergraphs
and further i dont know what to do? please help how to add codec
I did this:
#6For install codecs *.ax you need:cassinni wrote:thanks for your reply.
I did this:
1. Copy *.ax file in Filters folder.
2. Modify register.cmd: regsvr32 /s myFilter.ax (myFilter - for Example)
3. Run register.cmd.
4. Choose filter in programm settings.
#7Thanks for your quick answer.
With your help and a lil google i made it work, now i have an image. Just the audio now makes a clicking sound all the time, its not
as good as before. I use MPEG Audio Decoder for MPEG on my WinXP SP3 system.
#8Try use:cassinni wrote:Thanks for your quick answer.
Settings->Main->Demultiplexor - Prog
Settings->Audio->Codecs->DEfault audio Render - Prog Audio Render
And any audio codecs in list for MPEG.
#9just install x32 Professional on win 8 64 bit
and install K-Lite_Codec_Pack_980_Mega 64 bit
try and tell me
and remove all other codecs
try and tell me
