Hey there. I've been using ProgDVB and a DVB-C tuner on my PC for a while to watch the FTA channels on my cable provider without any major issues for a year.
However, recently, my Cable Provider decided to provide one HD channel on the FTA system. However, in my country, we use AAC LATM for the audio channels on HD transmissions, and I can't find a Plugin compatible with ProgDVB that will properly decode AAC LATM.
Anybody have any tips or any suggestions of Plugins that would both decode AAC LATM and work with ProgDVB on Windows?
Thanks in advance.
Re: AAC LATM Support
#3Thanks a lot! I tried CoreAAC and FFDshow, but they either didn't show up on ProgDVB or didn't work. DivX AAC from the DivX Codec Pack worked flawlessly.
Once again, thanks.
Once again, thanks.
