Easyblindscan for Progdvb
I modified a version of Easyblindscan 4.2 (freeware) to generate and update the Progdvb frequency ini lists, type .UserList. It is only aplicable to the cards that can do hardware blindscan.
The reason is that the internal blindscanner of Progdvb is badly designed, needs some work to become functional.
This solution only creates or updates the frequencies list, you then have to scan channels after the blindscan is done.
For those who know the Easyblindscan 4.2, this solution uses the BLScan2 engine option to generate the Progdvb ini files, but the BLScan main engine remains untouched.
To test it, download the modified Easyblindscan; unpack it where you want, make and save some profiles to the satellites you want to blindscan.
Edit the EBS.ini file to update the Progdvb\Transponders path as needed.
Easy way to use it:
1- open Progdvb, go to a channel of some sattelite. Close Progdvb.
2- open Easyblindscan, select the profile of the same satellite as above, and select the BLScan2 engine;
3- begin scan, wait end blindscan; if you want, look at the new UserList in Progdvb\Transponders
4- open Progdvb, delete all the channels of that satellite (this only in the very first time you use these new frequencies list to scan channels)
5 - do a normal scan frequencies of that satellite.
https://www.rapidshare.com/files/248654 ... ion%20.rar
