Re: problem with diseqc when used the function of NIT in sca
@star,
in version 6.86.4, I see no diseqc problems with the frequencies in lists, both NIT on or off.
Cant imagine influency of frequencies after a satellite is set with diseqc 1.0 or 1.1 switches.
Maybe when doing a satellite scan when NIT finds a new frequency this will not change correctlly a multiswitch with a quattro lnb?
Can you post the diseqc tree (devices configuration) here, so we can test it?
@ Star,
I tested NIT function with my Cband antenna and diseqc switch, and everything is working as expected (v 6.86.4 win 7 32bits).
All in NIT channels were found, and diseqc messages are correct. Unfortunatelly I dont have now pointed a Ku band sat to test NIT.
So, lets ask the obvious: did you enabled NIT search in the Tvsettings > Options > Scanner > Add to transponders list ?
@Prog,
Theres a bug in this NIT option "Add to transponders List".
No transponder is added to any list after a NIT scan, as I can understand from the title name.
The other two options, something with "Use only NIT if found..." i cant even understand what it is meant to do... If NIT frequency is found will Progdvb delete other frequencies :?: :? :shock:
