problem with video codec in ProgDVB6.87Pro !
some channel is black screen !
Re: problem with video codec in ProgDVB6.87Pro !
#4why you not attach files to forum? It is more simple. I am not like spend half hour to depositfiles
#5ok i am sorry the next time attach filesProg wrote:why you not attach files to forum? It is more simple. I am not like spend half hour to depositfiles
#7yes the same problemProg wrote:Still any problems in .1 version?
- Logs.rar
- (12.27 KiB) Downloaded 427 times
#8I have the same problem. new .1 version is a little better but still get black screen after channel change.
#9same , but sometimes not on every channel change... retry to open that channel will give the screen ...jaffo wrote:I have the same problem. new .1 version is a little better but still get black screen after channel change.
#10ProgDVB v6.87.1b works great for me!
Thanks Prog.
Thanks Prog.
#11no not goodjaffo wrote:ProgDVB v6.87.1b works great for me!
Thanks Prog.
crash and stop
- Logs.rar
- (18.11 KiB) Downloaded 447 times
