i have Diseq with 2 sat ( nilesat & hotbird )
suddenly nilesat not working and no signal .... but when i close prog and oper it again the first channel i switch on nile just work then no signal if i have swithed to another .... with hotbird no problem ...
i have do this :
uninstall & install ( progdvb & SS2 driver ) but no change
try nilesat on another dvbplayer and work without problem ( sorry to mention that )
More details, please...
What's the first LNB, nile or hotbird?
What kind of switch ( ~ method) ?
How about 'scan transponder'?
What are your 'distinguish by...' settings?
Does nile only fail if you try to use another transponder, or band or pola?
We're talking digital logics here, precision is a must...
Q 1:
the first nile and the second hotbird
Q 2:
move from channel to channel (( by mouse of that's intrest
Q 3:
make scan for first transporder then the signal off
Q 4:
By frequency
Q 5:
just if i switch to any channel from the start of prog it's work .... under any statu not working (((( i can view one channel in close & start prog from nilesat ))))
i know the expresion of my writing not good ... sorry for that
* the same problem faced me in the past and just formating and setup the windows solved it
Q 2:
Q 3:
Q 4:
By frequency
Q 5:
Then make a full backup right now...
And perhaps think about a system tool to watch registry changes, to get closer to the source of your trouble.
Might even be a good idea, to study your registry and perhaps also extract and store away some relevant parts, for a possible quick step back at any time.
OKJ, just to warn you, don't play with the registry editor, if you don't know what it does...
Easy to ruin Windows completely in no time at all...
