No DiseqC and Positioner setting in 6.87.4 pro
chipi
chipi
Sat Sep 22, 2012 11:00 am
#1 by chipi
After pay and install ProgDVB 6.87.4 pro I do not have in advance setting positioner and diseqc option. Registration is OK. Thanks for help.
  • Sat Sep 22, 2012 5:19 pm
marec
marec
Wed Jun 24, 2009 3:27 pm
Brazil
Re: No DiseqC and Positioner setting in 6.87.4 pro
#2 by marec
1- Did you add a positioner to your DVB device?
2- And the desired satellites to the LNBs ports?
3- Set unique numbers (or positions) to every satellite?
After that Progdvb will show a positioner buttom in the tool bar, for antenna adjusts.
  • Sun Sep 23, 2012 11:15 pm
chipi
chipi
#3 by chipi
Well I did not add positioner because when cklick in setting/Device options nothing happened. Do not open new window, nothing. I have skystar2 express hd. Thanks for your answer.
  • Mon Sep 24, 2012 5:19 pm
chipi
chipi
#4 by chipi
I found where was the problem. Instead to choose skystar2 eXpress hd card must take Technisat BDA Digital Tuner. After that have options for positioner or diseqc and got the positioner icon.
  • Mon Sep 24, 2012 8:21 pm
  • It is currently Tue Aug 25, 2026 1:19 am
