How to change the drive where ProgDVB saves the video?
z_zk_z
z_zk_z
Thu Nov 01, 2012 8:46 pm
#1 by z_zk_z
How do I change the hard drive letter, where the ProgDVB (DVR) saves the live TV video that is showing/saving?
Thanks for any help,
  • Thu Nov 01, 2012 9:11 pm
Re: How to change the drive where ProgDVB saves the video?
Settings->Options->Record?
  • Fri Nov 02, 2012 6:15 am
z_zk_z
z_zk_z
#3 by z_zk_z
That doesn't work. I am running ProgDVB (32-bit) under Windows 8 (64-bit). I know, it is saving video (live TV) because I can rewind but I cannot find the folder (nothing is under C:\Program Files (x86)\ProgDVB\Record either). HELP HELP HELP...
  • Fri Nov 02, 2012 10:31 pm
#4 by Prog
Check ProgDVB record settings.
  • Sat Nov 03, 2012 6:23 am
z_zk_z
z_zk_z
#5 by z_zk_z
The ProgDVB is not saving live TV under C:\Users\user1\AppData\Local\ProgDVB\Record directory because I don't see any file and I also have the Record setting pointed to a different drive and I still don't see any file while recording live TV.
Where does ProgDVB save the live TV recording file under Windows 8 64-bit?
  • Thu Nov 15, 2012 3:10 am
#6 by Prog
ProgDVB use path from record settings. No other places. But check rights. May be ProgDVB not have access for this directory.
  • Thu Nov 15, 2012 6:28 am
z_zk_z
z_zk_z
#7 by z_zk_z
It seems the ProgDVB saves live TV in main memory and it starts saving into hard drive by clicking "Start Recording" under the Service tab.
  • Thu Nov 22, 2012 1:21 am
  • It is currently Tue Aug 25, 2026 1:14 am
