BSOD after ProgDVB freezing
ProgDVB x86(or x64) 6.90.01
TBS DVBC USB Stick - version driver 2.0.0.2 (last)
Windows 7 Home Premium x86 (all updates)
I use PMS(home) unicast for LAN streaming.
After hours or days ProgDVB(server side) freezing and after restart computer has BSOD 0x000009F ("Driver Power State Failure").
If I kill task from task manager the process(ProgDvbNet.exe) is Suspended from Running, but not dead.
Please, help me!
Re: BSOD after ProgDVB freezing
I think the problem isn't the driver.
Program: ProgDVB Professional x86(or x64) 6.90.1 with active PMS(home/pro/large).
OS: Windows 7 Home Premium x64 (all updates)
try this method(A):
1. Open with /NoGraph (this is change to "Video renderer(OSD not supported)")
2. Minimized in tray
3. right click and close program.
4. Open program again(program started minimized)
5. Try open program from tray icon, this is impossible
but with this method(B):
1.Open without /NoGraph (set "Enhanced video renderer" manually)
5. Try open program from tray icon. NO PROBLEM! All works fine.
If I try kill process from task manager when ProgDVB is freeze the process ProgDvbNet.exe change status from "Running" to "Suspended".
I try this methods with x64 and x86 versions and Standart and Professional versions.
With "stability mode" or without - method A freeze and BSOD.
Sorry for my very bad english! :(
