v6.91.0 reports .NET 4.0 FULL not found even if installed
Kakadu
Kakadu
Fri Oct 01, 2010 10:26 pm
#1 by Kakadu
Is .NET 4.0.30320 no valuable ".NET 4.0 FULL or higher" version? When updating to ProgDVB 6.91.0 I am told to install .NET 4.0 even if it is installed.
What's wrong with the installed version?
  • Sun Nov 18, 2012 9:49 pm
Re: v6.91.0 reports .NET 4.0 FULL not found even if installe
Do you really have full 4.0? But you can really ignore this message if you only ProgDVB.
  • Mon Nov 19, 2012 6:25 am
Kakadu
Kakadu
#3 by Kakadu
Yes, it's full .NET 4.0 installed – but problem seems to be some system flaw of the OS; I'll probably have to reinstall the system on that PC ...
  • Fri Nov 30, 2012 11:58 pm
#4 by Prog
Do you sure? .net 4.0 have "client" version. But ProgTV request "full"
  • Sat Dec 01, 2012 6:33 am
Hello from new user
Just testing the forum. Great community here\!
michaelthomas7, Sat Jun 27, 2026 4:36 am
Вы мне логи крашей присылали?
  • It is currently Sat Jun 27, 2026 6:10 am
