Issue with Multiple Tuners and Recording via Scheduler
Hi,
I'm using ProgDVB (6.91.01, Professional, x86) with two tuners.
It works fine and I can manually record two different channels (one on each tuner) simultaneously.
But I'm having some difficulties when using the scheduler and trying to record simultaneously two channels.
Here is a simple example of the issues I'm having.
It should be easy to reproduce.
- Open "Channel A" on "Tuner 1"
- Start recording manually (suppose the time is 10:00:00)
- Open the scheduler and set it to start recording "Channel B" (which is only present on "Tuner 2") at 10:01:00.
Also set it to open the channel in a new window and to stop recording at 10:02:00.
- At 10:01:00 nothing happens, there is still only one window open with "Channel A", manual recording continues.
- At 10:02:00 the manual recording is halted on "Channel A".
If more info is needed let me know, thanks.
