Recording several channels at the same time???
Hi!
Can anyone help me by following questions:
1. Is it possible to record via ProgDVB several channels (PIDs) from the same transponder simultaneously?
2. Can ProgDVB work with several cards SkyStar2 simultaneously? (only for record, without viewing).
I guess it all would be possible if I could run several instances of ProgDVB at the same time, so can I do it?
If no, may be can anyone suggest any other software for it?
Thanks
Use several Progdvb installations..
The First one is running the media server...and nr. 2 and nr.3 etc...are running with the ´Prog media client : PiP Filters mode´ as device in device list...
No...
