ProgDVB pro 6.91.05
Hi every one
I installed ProgDVB pro 6.91.5 trial version,but there are two problems here
1. it closes itself suddenly
2. some frequencies does not work (no signal while before this version there were signals)
my DVB card is Azurewave AD-SB-200 USB
windows 7 64bit ultimate
Processor : Core i7 quad pro
Ram : 4Gb
VGA: Nvidia Geforce With CUDA technology
Please,anyone can help?
thanks
Re: ProgDVB pro 6.91.05
Thank you for your reply
I downloaded it yeasturday and I still have 29 days now,but I do not Understand what you are mean of diseq devices?!!
do you mean that if my Sat cable is attached to a Positioner and then from Positioner to the DVB card, yes it is.
I will try 32bit version,but what I heard that 64bit programs work more stable than 32bit version!
thanks
Hi again, there are many of them which one of these you want:
BDA.log
ProgDVBEngine.log
startup.log
UI.log
FilterManager.log
Scheduler.log
Network.log
I will upload it ,but I'd like to inform you that when I am turning Stability mode on,it works fine, why?
