ProgDVB 6.91.9 Lost all channels, no signal
Anakunda
Anakunda
Sun Apr 10, 2011 12:28 pm
#1 by Anakunda
I've updated , introduced TS Reader and lost all dvbt channels. Lost all prdedfined multiplexes. Blind search triggers nothing even if I set proper bandwidth. Manual search finds nothing even if I set up existing frrquency and bandwoth. AverTV still works good.
Please fix it.
  • Mon Jan 28, 2013 3:47 pm
Re: ProgDVB 6.91.9 Lost all channels, no signal
What you mean "TS Reader"? You must select some {bda} device in in TV Sources and check muxes in same place.
  • Mon Jan 28, 2013 3:56 pm
Anakunda
Anakunda
#3 by Anakunda
I did so
AverMedia A850 USB DVBT transponder
AF9015 BDA Filter
Channel list->Manual search
Source=AF9015 BDA Filter
Frequency=538000kHz
Bandwith=8MHz
Lock
Level=0%
Quality=0%
Standalone TV reports for this frequency 98% signal strength...I report this because before update ProgDVB was receiving signal with the same values..
  • Mon Jan 28, 2013 4:14 pm
#4 by Prog
Please send me bda.log from 9a prerelease.
  • Mon Jan 28, 2013 6:00 pm
Anakunda
Anakunda
#5 by Anakunda
I only have current BDA.log 6.91.9
BDA.ZIP
(1.16 KiB) Downloaded 345 times
  • Mon Jan 28, 2013 6:23 pm
#6 by Prog
Please send same log from prerelease
http://www.progdvb.com/download_progdvb_prerelease.html
  • Tue Jan 29, 2013 4:57 am
#7 by Prog
Public (b) prerelease. still need log.
  • Tue Jan 29, 2013 8:18 am
Anakunda
Anakunda
#8 by Anakunda
Public (b) prerelease is able to catch the signal. Thank you.
Do U still need the log? Didnot try the (a) prerelease...
  • Tue Jan 29, 2013 6:20 pm
#9 by Prog
I am need logs from last prerelease.
  • Thu Jan 31, 2013 3:14 am
Anakunda
Anakunda
#10 by Anakunda
Heres the logs from (b) prerelease
BDA.ZIP
(1.23 KiB) Downloaded 348 times
  • Fri Feb 01, 2013 11:08 am
#11 by Prog
Thanks! Please report me if any problems in future versions.
  • Fri Feb 01, 2013 11:22 am
  • It is currently Mon Aug 24, 2026 5:22 pm
