Hi,
I have last version on this date(6.91.09) and I'm trying to connect to computers in my home with progdvb media server(home)/client.
When I setup the ip address of the server port, user password it asks me if I want to scan the new channels and I press yes. It stats counting seconds en after some 30 seconds it disappears and no channels where downloaded from server.
I try to connect through telnet and it connects.
Can I have some debug information about some problem that is occurring.
How can I check what is wrong?
Best regards
Re: Prog media client isn't receiving channels
#3Hello,
I've tryed but nothing! I will buy the pro/small version but I would like to test it more! I had installed in this computer in the past. Could you give me one license of more 14 days or less to try it.
My hardhareid is: 105A-4E4B-5E3C-9DA0-7723-C994-5A52-14F9
Best Regards
Best Regards
#4try install client and server on same PC and setup on first step.
ps: You can try install Pro/large if need more 14 days of tests.
#6Hi!
I have tested with two installations on the same computer and it works.
I open the resource monitor on server and on another computer that has the client installed and I can see the connections being open and some bytes transferred but I get no channels on client.
Could you do this test?
Best Regards
Best Regards
#7Check network settings in client/server and firewalls on both PC.
#8Both Firewall were turned off and I could see on server the tcp connection from the client.
Is there any other way to debug the server module and the client device?
Best Regards
Best Regards
#9If no problem on local PC then problem in network... TCP?
