Latest version so bad
Latest version every time I start I must disable then reenable the TBS card just to watch any channel. WTF!? Otherwise it sits saying no signal etc. which is just crap. Signal is fine. Progdvb going so downhill. Always new versions and so little testing. This is so not how to develop software. You charge pro but you deliver amateur.
Re: Latest version so bad
I have some problems with my TBSs, too. It seems like the Crazycat module has a minimal level cutting off point, so "weak" signals (but with average S/N) sometimes wont give locking and quality. But the standard TBS drivers gets locking and fine video with that same signal...
By default the Crazycat is enabled after every update , but I think most of time is better not enable it (make HWControl=0 in TBS.ini file), and that is how it should be after a instalation or update.
Crazycat module has better frequency resolution than the TBS driver, and can lock some "bad" signals that TBS drivers wont lock, so if he can fix that low level problem, then enabling his module by default would be best way.
