Codec problems V6.92
Hi,
I did a clean install ov V6.92 on a clean Windows 7 x64 machine. Before installing ProgDVB I installed the Windows 7 codec pack. I tried on Windows 7 as on Windows 2008 R2 server I had a codec error message that I thought was related to the 2008 machine - but it is the same on Windows 7.
When I run ProgDVB I get an error 'Creation Audio renderer error' Stream Type MPEG: - Audio
I checked the settings -> options etc. and it looks ok (what should I be looking for particularly?)
I did a portable installation in c:\progdvb using the x32 version without the Elecard codecs.
What do I need to do to fix this?
Thanks
Re: Codec problems V6.92
It seems the pc would only install the audio when it had speakers plugged in ... strange!
Plugging in speakers sorted it out and now it works.
What doesn't seem to work though is the Media server. I set it up, configured, set to stream 3 channels and nothing. No streams. Any ideas what to look for?
Also (as previously) the Media Server does not retain the channels it is configured to stream when ProgDVB is shut down and re started. I get an empty list. The port and streaming type (Shoutcast) is preserved.
