Activation of Prog-TV don´t work
ete5
ete5
Sun Dec 16, 2012 9:53 am
#1 by ete5
I registred ProgDVB. But the new Prog-TV ask me every time I want to start it for activation-key. Then I put it in, it accept it, but at next time, I start it the same question for activation-key.
The activation-key is the right key.
Why does it not work?
  • Sat Mar 23, 2013 8:32 am
Re: Activation of Prog-TV don´t work
Try reinstall ProgDVB. Also use last version.
ps: Mail me your HID if still problem.
  • Sat Mar 23, 2013 10:09 am
ete5
ete5
#3 by ete5
I´ve got the same problem. Do I need a seperate Activation-Key for Prog-TV?
  • Sat Mar 30, 2013 1:46 pm
#4 by Prog
Yes, if you have license only for ProgDVB then need buy addition license for ProgTV (upgrade to "ProgDVB+ProgTV)
  • Sat Mar 30, 2013 2:32 pm
  • It is currently Mon Aug 24, 2026 6:58 pm
