Prog Media Client 4.00 - bug
momchil
momchil
Tue Aug 14, 2012 6:27 am
#1 by momchil
"Error! Host not found." after update with last version.
PMS is version 3.71.
All work perfectly with PMC 3.41.
  • Sat Mar 30, 2013 10:57 pm
Re: Prog Media Client 4.00 - bug
What mode? Do you use url from server interface?
  • Sun Mar 31, 2013 5:08 am
momchil
momchil
#3 by momchil
PMServer(3.71) mode: Multicast
Port: 10999
IP: Virtual VPN IP (clear IP, NOT URL address)
Packet size: 7400
I don't have any problems with old Prog Media Cleint 3.41.
  • Sun Mar 31, 2013 10:53 am
#4 by Prog
Ops. New client working only with new server generation.
ps: Why you use multicast for this mode?
  • Sun Mar 31, 2013 11:19 am
momchil
momchil
#5 by momchil
Prog wrote:Ops. New client working only with new server generation.
I hope you will fixed it. :)
P.S.: Because I have small local problem with Unicast. :) This is my local problem. I need UDP protocol for transport, but Unicast used TCP. :(
  • Sun Mar 31, 2013 11:49 am
#6 by Prog
Can you give me more details. I am not have no one reason for not TCP in Media Client mode.
  • Sun Mar 31, 2013 12:03 pm
momchil
momchil
#7 by momchil
This is my router problem. TCP has check error and this is slow, but with UDP I don't have any problems. :) This configuration is for personnal usage only. :)
You will fix it compatibility with new PMC and PMS(3.**)?
  • Sun Mar 31, 2013 1:13 pm
#8 by Prog
No. But may be I do this configuration in server 4.x. You can use same license for new server.
ps: May be problem in packet sizes?
  • Sun Mar 31, 2013 4:12 pm
momchil
momchil
#9 by momchil
Prog wrote: ps: May be problem in packet sizes?
I don't know. Now I use 6.92.04 and all work fine. :)
  • Sun Mar 31, 2013 4:26 pm
#10 by Prog
You can use ProgMediaClient.device from old versions in new ProgDVB.
  • Sun Mar 31, 2013 4:52 pm
momchil
momchil
#11 by momchil
Hm... This is good idea! Thanks! :)
  • Sun Mar 31, 2013 8:20 pm
Вы мне логи крашей присылали?
  • It is currently Sat Jun 27, 2026 2:26 am
