I've posted this in the German board but hope to get an answer faster here. A couple of days ago I reinstalled Professional x86, version 6.92.6 on my PC (Tevii S470 card). I updated the transponder list and scanned the channels. To my surprise I lost really many free German channels like Pro7, Sat1, Kabel 1, also some others like Puls Austria (they have lots of sports). Since then I have tried out many things: installation of numerous older versions, new transponder updates, several rescans, automatic and manual.
What I am facing is the following: There is no signal for the channels mentioned above (I know from my father's installation that they are still on air and still for free ). So when I scan and there are other channels on that same transponder, the other channels show up but my channels are missing in the list (e.g. 12.051 - V - 27500). Sometimes there is no channel at all found on a transponder (e.g. 12.545 - H - 22000). After an automatic scan this transponder is shown in the register card "not searched" in the window "search result" for the scan (there are about 40 transponders shown). When I do a manual scan, no signal is shown at that respective transponder.
Other than that everything is OK, e.g. my HD channels are all working OK, also some SD-channels.
I am a many-years-user of ProgDVB but right now I am out of ideas. Can anybody help?
Re: Lost signal for most SD channels
#2Do you have any diseq device?
Try remove Modules\tevii.ebd2 file.
#3I used to have a 22kHz switch in the past but in the course of finding the problem I use direct connection. There is no tevii.ebd2 file in the Modules directory.There is a tevii.eBDA file but erasing that does not do anything. Since you mentiomed Tevii: I updated their driver from Jan 2011 to Nov 2011 (the last one known), but only after the problems occured and I have switched back to the driver from Jan 2011.
I even did two quick new installatios after your message because somtimes I install to a BDA compatible and somtimes to the Tevii. I tried both with and without the tevii.eBDA by manual scan on 12.545 - H -22000. No signal anywhere.
This effect is just so weird. The simplest of all have just disappeared from the world for me..
#5I just went back to long past times and installed 6.49.09 and 6.60.02 on another partition even. Still the same problem. No signal at 12.545 and others
#6... and I did more.
I took the Tevii card out of the computer, uninstalled the driver, made sure there was nothing left in the registry, got rid of all the half-working ProgDVB installations and began putting things together again. Tried out version 6.87.06 this time. Still all the same.
Shame on me: I even installed another viewing program (DVBDream). Same phenomenon there. No signal on "simple" channels like on 12.545 - H- 22000 and others. I am beginning to think that the solution, if ever one turns up, will be very embarrassing to me.
#7Solved for now. Got an early start today. The fact that the problem persisted with other TV applications indicated naturally that it was not a ProgDVB problem. So I started searching for failings of that transponder in the internet. Numerous suggestions (from interfering DECT phones to a frequency drift in the LNB). Tried all those out, but nothing helped.
Fortunately I have two of everything. In the end I reactivated an old computer with another Tevii card, installed the newest ProgDVB. All transponders deliver a signal now as they are expected to do. So it looks like my Tevii card is broken in a very special way, i.e. it does not work any longer on some transponders. Can that really be?
For now I don't care. I earned praise from my soccer fanatic sons for having solved a problem just in time.
#9I also have two dishes with two cables coming in
So I guess it is the card. I will just buy a new one and see
#11none when testing the problem. I had a 22 Khz switch right before the card but took that out for testing
#12it was the mistakeSight wrote:switch right before the card
#13The switch worked for years without problem. I bought a new TV card and everything is fine again.
