Will ProgDVB work with my Standard KU LNB
I am located in the USA and looking at FTA
Satellites.
I have a WS International LNB Model ESX522
I am not sure what to set the LNB settings too. I have checked the voltage box.
The L.O. frequency on the box shows 10.75GHz
Should I set both high and low to the same frequency 10.75GHz
and the switch frequency to Zero ?
Mike
Re: LNB Settings
#2Set all fields to same value (look on LNB or box) or select Circulal polarization.
Please ask me if any problems with LNB.
Re: LNB Settings
#3Just want to Verify
For my Standard Ku Lnb with L.O of 10.75 GHz
I choose Ku Band Universal
LO 1 10750
Switch 10750
LO 2 10750
And put a check in the power box ?
or is the check not needed.
LO 1 10750
Switch 10750
LO 2 10750
