Hi
I have a problem with the ProgDVB service recordings.
The recording starts fine but everytime i want to check the status by clicking on the ProgDVB Launcher the recording stopped.
I have made a video to show the error.
http://youtu.be/rfrDe3EjmAQ
ProgDVB 6.94.06 Prof
Windows 7 64bit
Re: Prog Launcher stops my recordings
#3Yes Schedule recording with the ProgService feature.
In my YouTube Video i show what i mean.
I found something in the Scheduler Log:
14:29:01.826 - Error: Can not open SCM. Access denied.
Could this be the problem?
#5Even with admin rights (uac disabled) the recording stopped.
My Windows User has "Full Control" over the ProgDVB Install folder and the folder where the records are being stored.
#6Not same with admin rights. ProgDVB not have access to self Service. This is not important on normal situation but you can test this also.
#7Nothing works
Run as admin = same result. Installing it to a folder outside the programs files folder, portable/share all settings = same result.
And everytime i want to test it with a different user, i must reactivate the software.
Any Ideas? Am I the only one with this problem?
#9Today I have updated to Version 6.95.02 and now it works. Topic can be closed.
#11I'm back with my problem ^ ^
it worked only once after the update, now i have the same error as before.
In addition, I've recorded 10 HD movies but every file is corrupted. This only happens with HD movies i have recorded with the service. With the task scheduler this did not happen.
The picture below shows the errors (Videoredo)
#12Is it depended from launcher? Same with recording over MS scheduler?
ps: I think no good rights for ProgLuancher and service.
