ProgTV 1.05 Professional x86 - crash after activation
User avatar
cynik909
Sat Jun 27, 2009 9:54 am
#1 by cynik909
Hi,
First screen - activation - I fill all fields and press "Activation".
Later I have information that key is correct, please restart ProgTV.... OK!
After that, only crash window. Process repeats in endless loop :(
  • Fri Aug 09, 2013 2:01 pm
User avatar
cynik909
Re: ProgTV 1.05 Professional x86 - crash after activation
#2 by cynik909
Sorry, it isn't endless...
Report.zip
(657 Bytes) Downloaded 234 times
  • Fri Aug 09, 2013 2:30 pm
#3 by Prog
Try install to c:\ProgDVB. may be some problem with rights.
  • Fri Aug 09, 2013 3:40 pm
User avatar
cynik909
#4 by cynik909
It is so. I have ProgDVB directly on C:\
  • Fri Aug 09, 2013 4:10 pm
User avatar
cynik909
#5 by cynik909
I wanted to reinstall ProgDVB and try to activate once again.
I didn't want to wait till 2013-08-13 so I've changed system time/date... And now I have trial (-1 day) and can't watch TV till Tuesday.
Can't believe :(
  • Fri Aug 09, 2013 7:41 pm
#6 by Prog
Please send me all data on email.
  • Sun Aug 11, 2013 5:40 am
User avatar
cynik909
ProgTV 1.05 Professional x86- crash after activation [solved
#7 by cynik909
Now everything is clear. I had only license for ProgDVB Pro, not ProgTV.
Thanks for explanation Prog :)
My suggestion. Activation window should display an error: "You don't have valid license for..." instead of confirmation and crash ;)
  • Sun Aug 11, 2013 10:02 am
  • It is currently Tue Aug 25, 2026 1:12 am
